  3. Quantus QRC generates "nan" valued resistors. Spectre throws...
  • Views 2125
Quantus QRC generates "nan" valued resistors. Spectre throws an error and halts simulation
magal
magal over 6 years ago
Hi.
I'm running Quantus RLCK and I noticed that sometimes it creates on or two "nan" valued resistors (either using ladder-network model or not).
This doesn't happen for RC extraction.
The problem is that spectre then halts simulation and throws: " parameter `r': Cannot run the simulation because an unknown parameter `nan' has been specified in expression `-nan'. Correct the expression and rerun the simulation."
Am I doing something wrong? Currenlt, the best I can do is tweak layout to prevent there resistances from being generated
Assura: 4.1_USR6_HF3
Quantus version: 19.1.3-s062
Spectre: 161 through 191, latest USRs
Cheers,
Matan
    The issue is almost certainly related to the technology data you're using or some issue with the Quantus version. I'd suggest you contact customer support. I've seen examples where it's either the tool or the technology files for Quantus - and without knowing more about your technology that's going to be hard to diagnose - hence the suggestion to go to customer support.
  • magal
    magal over 6 years ago in reply to Andrew Beckett
    Thanks for the prompt reply. Will talk to customer support. I've narrowed down the occurrence of the "nan" resistor to the point where a metal trace connects to an RF-pcell in the layout.
    In other words - I think QRC expects the trace to be connected to a certain point in the (excluded BTW) RF-pcell, and otherwise detects an OC (?).
    Thanks again for the advice.
    Matan
