  3. modeling output impedance in a file
  • Views 15766
dzakharian
dzakharian over 6 years ago
hello,
i am trying to model an LDO as a norton equivalent network.  i can run an .ac simulation to get the output impedance vs frequency and export it as a file, but am having a difficult time figuring out how to attach this file (with magnitude/phase information) to a current source and then use that norton equivalent network in my simulations.  i was hoping it would be something akin to including a noise file for a vdc source, but i haven't found a way to do so.  is this even possible?
many thanks in advance.
    Providing an impedance versus frequency to a circuit simulator is not an entirely straightforward thing for it to deal with - because it's necessary to produce a causal time domain model from the frequency domain description.
    The normal way of doing this would be to perform an s-parameter analysis (sp) and then save the s-parameters from that and use them on an instance of an nport.
  • dzakharian
    dzakharian over 6 years ago in reply to Andrew Beckett
    Thanks Andrew, let me give that a shot.
