  3. plotting noise via Matlab
  • Subscribers 133
  • Views 16444
wgtkan
wgtkan over 6 years ago
My cadence Virtuoso version is IC6.1.8-64b.500.9 and my Spectre simulator version is sub-version 19.1.0.237.isr3
I am working with a PSP103 transistor model. I am simulating the DC operating point via a Matlab config file that will start the spectre simulation engine. The simulation runs fine and the netlist file is generated.
Here is my netlist file:
Here is my Matlab configuration file:
The Thermal and flicker noise setup is from line 80-82 in techsweep_config_psp_120_spectre.txt file
c.outvars_noise = {'STH','SFL'};
c.n_noise{1}= {'mn:sid', ''};
c.n_noise{2}= {'mn:sfl', ''};
Here is the main script that calls the simulator and cds_srr
The noise simulation setup is  from line 73 to line 86 in the techsweep_config_spectre.txt file and when I run the script, I get the following error:
Simulation Starts for L = 0.120
Simulation Finished for L = 0.120 with VSB = 1.00 V
Error: The special signal is not exist.
One or more output arguments not assigned during call to "cds_innersrr".
Error in techsweep_spectre_run (line 80)
struct_n = cds_innersrr(c.outfile, c.sweep_noise, params_n{1},0);
In this forum from a long time ago, a similar question was asked:
https://community.cadence.com/cadence_technology_forums/f/rf-design/19229/cds_srr-error
The replay was provided by the great Andrew Beckett.  "I've only seen this if either the directory name or the result dataset (second arg) is invalid for the data that exists - and then it gives a message before the error."  The answer to that is the result data set is valid.
"Also, I believe it may happen with non-spectre simulation results"  The answer to that is it is a spectre simulation result.
But when I do this:
cds_innersrr(c.outfile, c.sweep_noise, params_n{1})
Why is this error showing up? I have checked from PSP103p2 model summary that the flicker noise current spectral density is given by "sfl" and the channel thermal noise current spectral density is called "sid".
And when I do this:
cds_innersrr(c.outfile, c.sweep_noise), I get:
Total: 40 properties
'PSFversion' 'BINPSF creation time' 'ENV_VAR_0' 'ENV_VAR_1' 'ENV_VAR_2' 'ENV_VAR_3' 'ENV_VAR_4' 'ENV_VAR_5' 'ENV_VAR_6' 'ENV_VAR_7' 'ENV_VAR_8' 'ENV_VAR_9' 'ENV_VAR_10' 'ENV_VAR_11' 'ENV_VAR_12' 'ENV_VAR_13' 'PSF style' 'PSF types' 'PSF sweeps' 'PSF sweep points' 'PSF sweep min' 'PSF sweep max' 'PSF groups' 'PSF traces' 'simulator' 'version' 'date' 'design' 'analysis type' 'analysis name' 'analysis description' 'xVecSorted' 'tolerance.relative' 'operating point producer' 'output' 'output probe' 'output probe type' 'ground' 'positive output signal' 'negative output signal'
Total: 1 type(s) of signals
Signal type: A_sqrt_Hz_ Data type: Real
'out'
ans =
struct with fields:
signal_info: {'prop' 'Unknown' 'A_sqrt_Hz_' 'Real'}
prop: {40×1 cell}
A_sqrt_Hz_: {'out'}
I do not know what I am doing wrong?
Your help is highly appreciated.
  • wgtkan
    Any idea as to why it is not working?
    Andrew Beckett over 6 years ago in reply to wgtkan
    First of all if this was urgent enough for you to chase within a day, then you should contact customer support. I just looked at it and it needed a bit of work to adapt your examples so that it worked in my environment (without the model files) and I'm travelling this week so had limited time.
    The issue here is that you're giving the wrong signal names. They are not "sid" and "sfl". You have looked at the operating point parameters called these, but just because there are operating point parameters called that does not mean that these are the noise contribution parameters in the noise analysis.
    I opened the noise results in ViVA and saw they should be called "Sfl" and "Sthd" (I'm assuming these are the right names - the documentation on noise contributors is a bit lacking; maybe the NXP SimKit documentation covers this (I didn't check)).
    So around line 83 (approx) in the techweep_config code it should be:
    c.n_noise{1}= {'mn:Sthd', ''};
    c.n_noise{2}= {'mn:Sfl', ''};
    c.p_noise{1}= {'mp:Sthd', ''};
    c.p_noise{2}= {'mp:Sfl', ''};
    I also see no reason why you're using cds_innersrr rather than cds_srr. I'm not aware of this being buggy with noise - and it's cds_srr that's the public function. So I changed the calls to:
    struct_n = cds_srr(c.outfile, c.sweep_noise, params_n{1});
    struct_p = cds_srr(c.outfile, c.sweep_noise, params_p{1});
    All seemed to work OK when I tried it with these.
  • wgtkan
    wgtkan over 6 years ago in reply to Andrew Beckett
    This is incredible.
    It works like a charm. I agree that the documentation on noise with the NXP SimKit is quite limited.
    Thank you very much indeed.
