  3. Jop policy setting in ADEXL
  • Views 15572
NorNand
NorNand over 6 years ago
Is the number of " Max job" in job policy setting / ADEXL has a relationship to the number of tests?  or should I leave it always by default to 1 ?
Indeed I read the help documentation about it but couldn't understand how to perfectly setting it
Thank you in advance
    The number of jobs is the number of simulations you want to allow to be run in parallel. It's not really related to the number of tests, other than the fact that more tests, like more sweep points or more corners means you have more simulations to do - and having more that can run in parallel (assuming you have sufficient simulation licenses and compute resources) means that the total amount of simulations will complete sooner.
  • NorNand
    NorNand over 6 years ago in reply to Andrew Beckett
    Thank you Andrew for your answer,
    you made it perfectly clear
    Regards
