  3. Global net name mapping for spectre netlist
  • Views 16984
Amar Kumar
Amar Kumar over 6 years ago
I have generated a spectre netlist where it has below global nets.
global 0 vss! vdd!
Now, I want to get rid off the "!" sign and want something like "global 0 vdd vss" to appear it in my spectre netlist.
I have explored a bit and found with added below lines in .simrc , it does what I want exactly.
"hnlMapNetInName = list(list("+" nil) list("(" nil) list(")" nil) list("," nil) list("/" nil) list("." nil) list("$" nil) list("[" nil) list("]" nil) list("<" "[") list(">" "]") list("!" nil) )"
But the above method works for CDL netlist.
Is there any way to get similar thing done in spectre netlist also ?
Thanks In Advance!
Amar
    Hi Amar,
    I'm not sure this is a good idea, but you could use a different variable to do this specifically for spectre. See Name mapping for spectre netlisting has changed in IC61X
  • Amar Kumar
    Amar Kumar over 6 years ago in reply to Andrew Beckett
    The "hnlSpectreMapNetInName" variable worked great with old mechanism.
    Thank you very much for your continuous help.
    Amar
