  3. What does such sign mean in the data view
  • Views 15286
sjwprc
sjwprc over 6 years ago
Does any one know the meaning of such a sign in the data view? why it is different from others?
  • wgtkan
    wgtkan over 6 years ago
    These are your simulation history where ADE XL saves them as your interactive. Things such as netlist, tests, psf, and so on are saved. You can limit the number of history to save by going to option menu.
    Andrew Beckett over 6 years ago in reply to wgtkan
    The highlighted item suggests that it's a readonly history (i.e. the simulation was performed in readonly mode). What's a bit strange is that in ADE XL normally those "readonly" histories are lost when you re-open again in edit mode (so I would only expect these "readonly" histories to appear at the end). It's different in ADE Assembler, as that will continue to be able to see any readonly histories (which have ".RO" on the end) in subsequent sessions.
  • sjwprc
    sjwprc over 6 years ago in reply to Andrew Beckett
    Quite clear, Andrew, thanks a lot!
