  3. Simulation of an inverter using FinFETs
  • Views 16417
pradeep22
pradeep22 over 6 years ago
Hi , I'm trying to simulate a simple inverter circuit using FinFET  , I have downloaded the ASAP7_PDKandLIB and added its path in library path editor .
Now when i try to simulate it in ADE L , I'm not able to get any waveforms  . I'm getting the following error.
ERROR (OSSHNL-116): Unable to descend into any of the views defined in the view list, 'spectre cmos_sch cmos.sch schematic veriloga', for the
instance 'M0' in cell 'inv'. Either add one of these views to the library 'finfet',
cell 'nmos_lvt' or modify the view list to contain an existing view.
End netlisting Feb 24 21:40:58 2020
ERROR (OSSHNL-514): Netlisting failed due to errors reported before. Netlist may be corrupt or may not be produced at all. Fix reported errors and netlist again.
...unsuccessful.
Any help will be most appreciated.
Thank You
Pradeep
    Hi Pradeep,
    You probably would be best contacting ASU about this: http://asap.asu.edu/asap/
    I can't download it to take a look because the PDK license says it can only be used by academic and educational institutions only.
