  3. PVS - QRC RUN FAILURE--LBMISC-215294
  • Views 2325
zhaoyang
zhaoyang over 6 years ago
Hi there,
I was running a PVS- QRC but ran into an error--ERROR (LBMISC-215294): can't open string file /tmp/strtabx45RH3 in map_file_to_strtab ().
PVS version is 15.2
The QRC is Version 13.2.0-s329.
The whole log file is:
Cadence Extraction QRC - 64-bit Parasitic Extractor - Version 13.2.0-s329
Tue Apr 15 20:11:01 PDT 2014
Copyright 2013 Cadence Design Systems, Inc.
INFO (LBRCXM-642): Constructing the RCX run script
WARNING (RCXSPIC-27104): p2lvsfile in tech directory does not have resistance
temperature coefficients (TC1, TC2). ?temperature is ignored
INFO (RCXSPIC-27150): The following forked command failed. Contact Cadence Customer Support for assistance.
agdsPrep -V -rundir /tmp -outdir /tmp/row_inv_x1 -sch -df2 -e /tmp/row_inv_x1.gds.map:row_inv_x1.alm,row_inv_x1.ilf -pl row_inv_x1.ports -mcell /tmp/row_inv_x1/row_inv_x1.hcl -l /tmp/row_inv_x1.lvsfile -i row_inv_x1.ixf,row_inv_x1.lph,row_inv_x1.sph:row_inv_x1.gdx -n row_inv_x1.nxf,row_inv_x1.stl:row_inv_x1.gnx -s row_inv_x1_pin_xy.spi:row_inv_x1.xcn,hccidtmfile
Forking: agdsPrep -V -rundir /tmp -outdir /tmp/row_inv_x1 -sch -df2 -e /tmp/row_inv_x1.gds.map:row_inv_x1.alm,row_inv_x1.ilf -pl row_inv_x1.ports -mcell /tmp/row_inv_x1/row_inv_x1.hcl -l /tmp/row_inv_x1.lvsfile -i row_inv_x1.ixf,row_inv_x1.lph,row_inv_x1.sph:row_inv_x1.gdx -n row_inv_x1.nxf,row_inv_x1.stl:row_inv_x1.gnx -s row_inv_x1_pin_xy.spi:row_inv_x1.xcn,hccidtmfile
ERROR (LBRCXM-644): Bad return status from RCX script generator. 0x100
INFO (LBRCXM-709): ***** QRC terminated abnormally *****
Yang
  • Saloni Chhabra
    Saloni Chhabra over 6 years ago
    Hi Yang,
    You are using a very old QRC version, so please try with a newer one. If the issue doesn't go away, please contact Cadence customer support.
    Saloni
  • zhaoyang
    zhaoyang over 6 years ago in reply to Saloni Chhabra
    Hi Saloni,
    I just tried the Cadence 618 and QRC 19.1. It still gives me the same error.
    Yang
    Andrew Beckett over 6 years ago in reply to zhaoyang
    Hi Yang,
    There's never been a report of this, so please do as Saloni suggested and contact customer support. This forum is not customer support...
  • zhaoyang
    zhaoyang over 6 years ago in reply to Andrew Beckett
    Okay. Thanks!
    Yang
