  3. Problem in accessing the X-values of a signal waveform
  • Views 17429
NorNand
NorNand over 6 years ago
I have this attached waveform that represents a frequency response of a model,
I am trying to find the frequency at where the output is maximum which represents for me the f2. the f1 I should find it as usual as for first-order circuits by multiplying the passband amplitude with 0.707 (which represent the - 3 dB), then f1 is the frequency at the resulted value.
I am trying to do it from Cadence calculator but looks like Xval function is not working,
for example Calculator is not giving me the Xval for the Ymax(Outputcap) to get f2, the same problem when trying to find f1
For your kind concern
Thank you
    Not sure how OutputCap is being calculated, but it's possible that it's a complex number and so ymax doesn't work on it. Perhaps you need to do ymax(mag(OutputCap)) ? That would give the frequency where the magnitude of the OutputCap is maximum. Given the fact that the y axis shows Mag (fF) I suspect it is indeed a complex value (AC analysis results are normally complex, and then when plotted it wlll plot the magnitude by default, but functions like ymax, ymin etc do not automatically perform the mag() for you).
  • NorNand
    NorNand over 6 years ago in reply to Andrew Beckett
    Dear Andrew
    Thank you for your reply
    you are right, ymax was not working with me until I took the magnitude mag(OutputCap). However, Ymax will not give the frequency where the OutputCap is maximum, it gves me the value where OutputCap is maximum, means this function return the maximum y value while I am intereseting in the x value at the ymax, I already tested it.
    to find f1 I am doing the following but also not working:
    1. Applying Value function to OutputCap at f= 1 kHz
    2. Multiplying the value with 0.707
    3. applying Xvalue to the last steo in 2
    Thank you Andrew once again
    Regards
    Andrew Beckett over 6 years ago in reply to NorNand
    Sorry, I should have said you need to use xmax rather than ymax- this returns the x value where the maximum y is located.
  • NorNand
    Thank you Andrew for your suggestion
    it is working now
