  3. . dot vs / slash when saving signals in Ocean
  • Views 15533
zaratustra
zaratustra over 6 years ago
I'm exporting all the net voltages (for a specific time) from a circuit and I noted that if I perform the simulation with APS++ and XPS the signals are saved with the slash notation. Example:
option( ?categ 'turboOpts
    'apsplus  t
    'uniMode  "XPS MS"
In this case the signals are saved as:
/NET<0>
/I0/netX<0>
If I simulate with spectre only the signals are saved as:
NET\<0\>
I0.netX\<0\>
Note the \ to scape the <> too.
Is there an option to set one style or the other ?
    Andrew Beckett over 6 years ago +1
    Hmm, this doesn't sound correct to me. Spectre actually always saves signals with the dot hierarchy separator, because that's Spectre's namespace - it has to match the names in the netlist. However, in…
    Hmm, this doesn't sound correct to me. Spectre actually always saves signals with the dot hierarchy separator, because that's Spectre's namespace - it has to match the names in the netlist. However, in the results browser, names are normally reverse mapped into "schematic" names (i.e. names that begin with slash, and use slash as the hierarchy separator). So effectively requests to save signals or probe signals start from a hierarchical schematic names (with slashes) and end up translated to spectre's namespace, and then when you look at the named results (e.g. with the outputs() function in OCEAN or the results browser, they're translated back into schematic names).
    In OCEAN you can normally do:
    selectResult('tran)
    outputs()
    or
    outputs(?map nil)
    (the latter will show the unmapped names).
    I see no reason why it being APS/XPS or spectre would make a difference to this mapping.
  • zaratustra
    zaratustra over 6 years ago in reply to Andrew Beckett
    Thank you, Andrew. I will give it a try with outputs(?map nil).
