  3. window focus policy issue (Always focus Navigator first...
  • Views 16102
window focus policy issue (Always focus Navigator first time)
jwchoi
jwchoi over 6 years ago
I use Cadence version (IC6.1.8-64b.500.9).
When I open Virtuoso schematic or layout, the Navigator is focused first time, so I can't do any infix command before I click or move out cursor and move in again.
Once I click the schematic window or move cursor out and in, the focus policy ( CanvasDelay) is working correctly.
When I use version IC6.1.8-64b.500.6, there is no issue about that. However I change the version later 500.8, it happens.
Do you have any ideas?
    I suggest you contact customer support.
  • FormerMember
    FormerMember over 6 years ago
    Thanks for your post, I thought it was just me. I had the same problem and found removing the following file fixed it:
    .cadence/dfII/Navigator/Options.xml
    I have opened a case.
  • WernerZ
    WernerZ over 6 years ago in reply to FormerMember
    Hi John and Andrew,
    I tried your proposal and it worked in the first moment. But as soon as I clicked for example at 'Navigator > OBJECTS > All' the same unwanted mouse focus behavior (always at Navigator after closing a schematic with CTRL-W) appeared again.
    But just now I found a new version ICADVM 18.10.100 (18.1-64b.500.10) available in our cadenv and I tried it immediately => it works now as expected even with the original Options.xml :-)
    Best regards,
    Werner
