  3. I want a user manual for the switch in analoglib. where...
  • Subscribers 136
  • Views 21065
I want a user manual for the switch in analoglib. where I can get this?
JAYDIP BISWAS
JAYDIP BISWAS over 6 years ago
    Did you try looking in the Analog Library Reference manual? This can be found in Virtuoso by typing in the text box at the top of any Help menu, "Analog Library Reference". This has a page on the switch component where it also says that the component is "relay" in spectre and you can use (on the UNIX command line) "spectre -h relay" for more details of the underlying component. The same manual is also available on support.cadence.com too of course: Analog Library Reference -- 5 - Symbol: switch
