  3. How to measure the performance of a PLL ?
  • Views 14826
JJJin
JJJin over 6 years ago
I recently built up a CMOS PLL circuit .  And so far, in the trans simulation, it would be stable (locked to reference frequency) after a few uS.
My questions are :
1. What kind of simulations would be applied to measure the performance of PLL in general? Because we can only run the trans simulation right now.
2. I tried to run pss, however, as we have another signal source as reference signal, pss simulation would not tolerate that. Is PSS possible and necessary?
3. I tried to run HB simulation, the data it generated is soooooo much which filled our disk and errors showed up. So I guess that is impossible for me .
4.I saw many papers ploting the closed loop gain and phase margin. But I don't know what simulation gives that result ? What should I do if I want to see the closed loop gain and phase margin ? What's the meaning of that two figues?
5.The simulation for the whole circuit usually takes few hours with aps++ . Will it be faster if I use spectre X ? It is said it would be faster 3-10 times in the Ad.
If anyone has any suggestion or experience and would like to share with me, I would be grateful.
Thank you !
