  3. Segmentation fault in a PSS simulation (ADE-XL)
  • Views 19704
threepwood06
threepwood06 over 6 years ago
Hi Andrew/someone,
I have a testbench in ADEXL (a PSS simulation) that returns a segmentation fault.
I am said to "submit the case via Cadence Online Support", could you please explain to me exactly the procedure to follow?
Can I submit my netlist only? is the tar file necessary? if so in which path do I run the "mmsimpack" command and which command exactly may I run?
etc, etc...
Sorry again for my "noobitude" in Cadence CAD/Unix :-)
Thanks and best regards
    The first thing I'd suggest is contacting customer support describing the problem and providing the simulator log file (assuming it's the simulator that is failing with a segmentation fault). You can log a case on the support site that I linked to.
    One possible cause with PSS might be that it's running out of memory because PSS is more memory intensive than non-RF analyses. So you might want to use Setup->Environment in the test editor in ADE XL and enable "64 bit", which will allow spectre to access more memory (assuming it's available on the machine) - 32 bit applications can only access a max of 4Gbytes of memory because of the maximum 32-bit address space.
    Customer support are likely to want a test case (normally we'd also get you to check using latest versions first, because if you're not using something recent it may already have been fixed). Precisely what they want will depend a bit on the problem - one possibility is to use the mmsimpack tool (which is available on the command line from the spectre releases), but normally you'd have to tell it some further info to filter out foundry models as you probably are not allowed to share them with us (we obtain them separately from the foundry to ensure nobody is breaking any non-disclosure agreements).
