  3. How to add a new component-part in Virtuoso
  • Replies 14
  • Views 27663
Sali
Sali over 6 years ago
Hi ,
I have this spice code from ALADIN website, it is supposed to be the spice file for two nmos transistors connected in a certain way in one chip as in the attached figure.
I want to create this new component in Virtuoso to uses in the schematic.
I searched a lot around and I found CDF editing tutorial but it does not work since the parameters does not show up in the CDF form. Could any one help me in this.
Thank you
Moderator: Removed model contents since it's probably released under license by the part vendor
    This appears to be a PSPICE model (I'm not sure you really should post it here, but I couldn't find the source to reference it). The simplest way ought to be to just create a new view of type "pspice" (so do File->New->CellView and set the type to be "Pspice". Paste the text of the model (you'll need to ensure your cellName matches the subckt name, so you could call the cell 114913 if you don't want to change that part of the text).
    Spectre however does not support the tolerance parameters in a PSPICE model, so you'd need to remove the lot/4/uniform=-.22 dev/uniform=.04 type specifications for each parameter. Then do a File->Extract and it will prompt you to create a symbol if you don't have one (there are five pins called 1 to 5).
    However, it still won't simulate in spectre because it references a diode model called "dps" which is not defined anywhere. I just added:
    .model dps diode
    and it ran, but of course that's completely invented...
  • Sali
    Sali over 6 years ago in reply to Andrew Beckett
    Thank you so much Andrew for your detailed answer.
    For the reference of spice model , this is the link and it shows only when you create an account and log in there.
    https://www.aldinc.com/view-pdf.php
    I will follow the steps and try it.
    Thanks again.
  • Frank Wiedmann
    Frank Wiedmann over 6 years ago in reply to Sali
    You also might want to take a look at the Rapid Adoption Kit "PSPICE Netlist Support in ADE" at https://support.cadence.com/apex/articleattachmentportal?id=a1O0V0000091D0vUAE
  • Sali
    Sali over 6 years ago in reply to Frank Wiedmann
    Thanks frank it is a very useful guide
  • Sali
    When I opened new cell view, I chose the view : Spice, Type : Spice but the open application field shows only read HDL which open something like vi editor after I finish copy and past the spice text, I exit by ":wq" command and no  symbol creation window pops up.
    Is there anyway to solve this ?
    Thank you in advance,
    Andrew Beckett over 6 years ago in reply to Sali
    First of all, I said to use "pspice" not "spice" because this is a PSPICE-compatible model, not SPICE. Secondly, I think you must be using too old a version. So please:
    1. Report which version of the IC tools you're using (Help->About in any window will tell you this - please provide the entire number) and Spectre (this will appear near the top of any spectre log file from simulations  you perform in ADE)
    2. Check if you have access to a later version of either/and the IC tools and spectre - almost certainly you'll need something more recent to make this work. There might be a workaround if using a recent enough spectre, but I'll have to check based on what the latest you have available, rather than me determining every possible solution in advance.
  • Sali
    Thanks Andrew, the version I am using is IC6.1.5, I tried another version IC6.1.8 and I was able to create the symbol of the model, in this version I did not find resistors,gnd and sin wave generator so I returned back to the version I use and have an error attached below.
    I also attached the versions of both Virtuoso I use, for the ADE I found it is the same as Virtuoso version.
    This is the version I usually use:
    The error I received:
    The other version I used to create the symbol:
    I'm not sure what you mean by that. Do you mean that you didn't have analogLib in your available libraries? The only explanation for that is that you've not got it correctly defined in your cds.lib - you should have this:
    DEFINE analogLib $(inst_root_with:tools/dfII/bin/virtuoso)/tools/dfII/etc/cdslib/artist/analogLib
    and then it will always pick up analogLib from the current installation.The $(inst_root_with ...) is special syntax to allow it to locate an installation with virtuoso in based on the UNIX path.
    I think it's unlikely to work if you create the pspice view in IC618 and then go back to IC615, because it won't know how to netlist that view as this wasn't supported in such an old version. The specific failure you show is because you need to put "pspice" (or whatever you called the view) in the switch view list in Setup->Environment in ADE - you'll need to do that in IC618. I think that even if you did that in IC615 it will stil fail but in a different way.
  • Sali
    Yes I do not have the analogLib.
    I have this error when I tried to install the missing Lib:
    *Error* eval: undefined function - DEFINE
    <<< Stack Trace >>>
    DEFINE(analogLib ((inst_root_with:(tools / dfII / bin / virtuoso)) / tools / dfII / etc / cdslib / artist / analogLib))
  • Sali
    Sali over 6 years ago in reply to Sali
    I was able to use another version (attached below) it is the same ADE version
    I repeated all the steps of creation the pspice symbol then I added pspice in the ADE>setup>environment>switch list beside verilog spectre,....
    Unfortunately I got this error (attached) , also I attached input.scs
    Fullscreen 3326.input.txt Download
    // Generated for: spectre
    // Generated on: Mar 28 22:34:52 2020
    // Design library name: Testing2
    // Design cell name: SchematicspiceALD5
    simulator lang=spectre
    global 0
    include "/CMC/kits/cmosp13.V1.8.0.0DM/IBM_PDK/cmrf8sf/V1.8.0.4DM/Spectre/models/design.scs"
    include "/CMC/kits/cmosp13.V1.8.0.0DM/IBM_PDK/cmrf8sf/V1.8.0.4DM/Spectre/models/allModels.scs" section=tt
    // Library name: Testing2
    // Cell name: SchematicspiceALD5
    // View name: schematic
    I4 (net2 net08 net3 0 net09) spiceALD6 vtn=-1.3811 vtx=vtn cox=1 ires=0.41 \
            pox=1 __hspicem=1
    R0 (net3 0) resistor r=4K
    V0 (net2 0) vsource type=sine ampl=3.3 freq=1
    simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
        tnom=25 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
        checklimitdest=psf
    tran tran stop=1 errpreset=moderate write="spectre.ic" \
        writefinal="spectre.fc" annotate=status maxiters=5
    pspice_include "/home/salibensuleiman/thesis/Testing2/spiceALD6/pspice/design.pspice"
