  3. Variable Pnoise Stop Frequency
  • Views 16674
Conorp
Conorp over 6 years ago
IC 6.1.8.090
ADE Explorer
I am running a shooting PSS analysis to determine the output frequency of an oscillator. I also run a PNOISE analysis to report a Jitter measurement based on this PSS.
However, the oscillator output frequency varies over PVT. I would like my PNOISE simulation to have a stop frequency of half the oscillation frequency over corners.
Is this possible (or even reasonable...)? (Taking the calculated oscillator frequency and passing that value to the PNOISE analysis setup.)
Many thanks,
Conor
    Andrew Beckett over 6 years ago +1
    Hi Conor, Right now, this isn't possible. I filed an enhancement request a little while back asking for exactly this: CCR 1869944 Provide mechanism to sweep sampled pnoise/hbnoise to half pss fundamental…
    Hi Conor,
    CCR 1869944 Provide mechanism to sweep sampled pnoise/hbnoise to half pss fundamental for autonomous circuits
    It would be a good idea if you contact customer support referencing this CCR (and this post) and ask for a duplicate to be filed - that will help with prioritisation.
  • Conorp
    Conorp over 6 years ago in reply to Andrew Beckett
    Many thanks for your reply Andrew.
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago in reply to Andrew Beckett
    The CCR has now been implemented in SPECTRE191 ISR13. Andrew, could you please briefly describe how to use the new feature?
    Andrew Beckett over 5 years ago in reply to Frank Wiedmann
    Frank,
    I wrote this article, which has a release date of today (to coincide with IC618/ICADVM201 ISR15 which is where it is supported from the ADE UI): How can I set the stop frequency for a sampled pnoise/hbnoise analysis to be half the PSS fundamental? (not sure whether that's visible yet externally).
  • Frank Wiedmann
    It's not ("The content you are trying to access has been retired and is no longer available."), but I can wait a few more hours, no problem. Thanks for the quick response.
