  3. Is it possible to get ADEXL simulation parameters and all...
  • Views 14901
Is it possible to get ADEXL simulation parameters and all other related input stimulus
Genas
Genas over 6 years ago
I have an ADEXL maestro view which I can run simulations by opening the view and pressing the green button, however, I want to run the simulations using spectre from command line.
To do this I need a way to extract all the simulation information (netlist, input stimuli etc) to a file so I can run the simulation from the command line using spectre and the extracted file.
I will appreciate any assistance with this.
I am using IC6.1.7-64b.500.20
Genas
  • Marc Heise
    Marc Heise over 6 years ago
    Hi Genas,
    after a the Maestro simulation you can right click into one of the result outputs and choose "Open Terminal", that will give you a new terminal at the location with the netlist and psf folder. All info
    you need is in the netlist folder.  There is also the "runSimulation" file, which you could execute to rerun.
    Kind regards,
    Marc
