  3. How do I sweep a simulator option parameter (gmin, vabstol...
  • Views 17319
How do I sweep a simulator option parameter (gmin, vabstol, rforce,...) in ADE Explorer / XL?
Johanny Saenz
Johanny Saenz over 6 years ago
HI all,
I'm trying to optimize the circuit convergence and I would like to sweep parameters  like gmin or rforce, which are defined in the simulator option card.
How I could do it? Any suggestion?
Thanks in advance
    Andrew Beckett over 6 years ago +1
    A slightly odd thing to do, but you can set the gmin or rforce in the Simulation->Options->Analog to (say) VAR("GMIN") or VAR("RFORCE") and then you'll have a design variable in ADE called GMIN or RFORCE…
    A slightly odd thing to do, but you can set the gmin or rforce in the Simulation->Options->Analog to (say) VAR("GMIN") or VAR("RFORCE") and then you'll have a design variable in ADE called GMIN or RFORCE that you can then sweep. It will automatically create the variable - you have to supply the default value or sweep condition.
