  3. Unwrap a waveform
  • Replies 7
  • Subscribers 136
  • Views 22721
Unwrap a waveform
debaabed
debaabed over 6 years ago
Hi All
In Viva, is there a function available to unwrap a waveform by defining its wrap-over value. For eg: please see the below plot. I want to generate lower plot from the upper plot. There are phaseDegunwrap and phaseRadunwrap, they don't serve this purpose.
I would be grateful if I can get few pointers towards solving this.
    ShawnLogan over 6 years ago in reply to debaabed +1
    Hi Debasish, debaabed said: I want to generate lower plot from the upper plot such that it removes the discontinuities and result in a continuous function. I now understand. Thank you for clarifying…
    Andrew Beckett over 6 years ago in reply to debaabed +1
    OK, understood. Hopefully this does what you want? (you can add to the calculator using the fx button in the function panel or in the expression builder) if using IC617/IC618: Regards, Andrew …
    Dear debaabed,
    debaabed said:
    In Viva, is there a function available to unwrap a waveform by defining its wrap-over value. For eg: please see the below plot. There are phaseDegunwrap and phaseRadunwrap, they don't serve this purpose.
    I am a little confused about which plot you are trying to create - the upper plot from the lower plot or the lower plot from the upper plot? From your description of your question, "to unwrap a waveform by defining its wrap-over value", I think you want to create the upper plot from the lower plot (i.e., unwrap a waveform with some modulus).
     If so, you essentially are applying a modulus function to a waveform. There is a SKILL function that Cadence has provided for this purpose. It is described in the article at URL:
    support.cadence.com/.../ArticleAttachmentPortal
    Does this help at all debaabed?
    Shawn
  • debaabed
    debaabed over 6 years ago in reply to ShawnLogan
    Hi Shawn
    I should have been more clear. I want to generate lower plot from the upper plot such that it removes the discontinuities and result in a continuous function.
    Thanks and Regards
    Debasish
    Hi Debasish,
    I now understand. Thank you for clarifying your question! Hence, the function I pointed you to is not what you want. Sorry.
    Other than functions like "phaseDegUnwrapped()" or its radian equivalent, I am not familiar with a specific function that will accomplish exactly what you want. However, an ocean script that works something like the following might be an approach.
    1. For a waveform y that is limited to some value YLIMIT and periodic with multiple values of YLIMIT, create a new waveform y_prime = y + DELTA where DELTA is  some constant less than YLIMIT that causes y_prime to cross YLIMIT multiple times
    2. Use the cross() function to find the crossing numbers of function y_prime of YLIMIT (use the cycle and time  options of cross()).
    3. For all times of the crossing points of y_prime that are returned, create your desired waveform y_desired as the sum of y and the crossing number*YLIMIT at each crossing time.
    4. Plot the waveform y_desired and compare to the plot of y.
    I am sure this algorithm can be implemented in SKILL if you prefer.
    Hope this provides you some help even though it is not a defined function.
    Shawn
    Andrew Beckett over 6 years ago in reply to ShawnLogan
    There isn't any public function that does this, as far as I know. Whilst there is a private function used within phaseDegUnwrapped and phaseRadUnwrapped, it's not general purpose (only works for complex data).
    What is generating this modulo-pi data? I'd like to understand where it's coming from so that I can make a suitable recommendation as to how this could be written.
  • debaabed
    debaabed over 6 years ago in reply to Andrew Beckett
    Hi Andrew
    Let me explain the problem. I need to extract the parameters for a transmission line. I have the transmission line electromagnetic model extraction from Integrand software. To extract the RLGC data, I am following one of the methods which uses open circuit and short circuit impedance. Please see the reference
    S-parameter-based IC interconnect transmission line characterization, IEEE Transactions on Components, Hybrids and Manufacturing Technology, Vol. 15, Issue:4, Aug 1992
    While calculating the gamma (propagation constant) for the transmission line, its imaginary part has these modulo-pi data. But to use them to calculate the RLGC data, unwrapped gamma is needed.
    The equations are described below. The below code is from ADS.
    I hope I have conveyed my issue. Please let me know.
    DB
    /* abUnwrap.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Apr 06, 2020
    Modified
    By
    Provides calculator function to unwrap with arbitrary modulus. Looks
    for sudden large point-point steps in the value.
    Usage:
    abUnwrap(phase(VF("/sig")) 180.0)
    Can also be added to calculator by using the fx button in the function
    panel or expression builder in Explorer/Assembler, as the code
    contains the UI template too.
    SCCS Info: @(#) abUnwrap.il 04/06/20.11:10:48 1.1
    ; test data
    ; wv=abMakeWaveform(lambda((x) modf(x 1.2u)*1e6) linRg(0 10u 0.09u))
    ; wv=abMakeWaveform(lambda((x) modf(-x 1.2u)*1e6) linRg(0 10u 0.09u))
    *     (abUnwrap wave modulus @optional (maxRelativeDelta 0.5))     *
    * Unwraps a waveform (note, this must be non-complex data) with an *
    *   arbitrary modulus. Unwraps any sudden steps of greater than    *
    *                     maxRelativeDelta*modulus                     *
    (defun abUnwrap (wave modulus @optional (maxRelativeDelta 0.5))
      (cond
        ((drIsWaveform wave)
         (let (xVec yVec newYVec len (correction 0.0) y prevY delta
                    maxAbsoluteDelta)
           (setq maxAbsoluteDelta (times modulus maxRelativeDelta))
           (setq xVec (drGetWaveformXVec wave))
           (setq yVec (drGetWaveformYVec wave))
           (setq len (drVectorLength xVec))
           (setq newYVec (drCreateVec (drType yVec) len))
           ; If any successive delta is greater than 50% of the modulus (in a single
           ; step by default) then compute a cumulative correction to keep adding
           ; to the output waveform
           (for i 0 (sub1 len)
                (setq y (drGetElem yVec i))
                (when prevY
                  (setq delta (difference y prevY))
                  (when (geqp (abs delta) maxAbsoluteDelta)
                    (setq correction
                          (plus correction (if (plusp delta) (minus modulus) modulus)))
                (drSetElem newYVec i (plus y correction))
                (setq prevY y)
           (putpropq newYVec (getq yVec units) units)
           (putpropq newYVec (getq yVec name) name)
           (drCreateWaveform xVec newYVec)
        ((famIsFamily wave)
         (famMap 'abUnwrap wave modulus maxRelativeDelta)
        (t
          (error "abUnwrap: can't handle %L\n" wave)
    ;;;;;;;;;;;;;;;;;;;;;;;;;; GUI builder information ;;;;;;;;;;;;;;;;;;;;;;;;;;;
    ocnmRegGUIBuilder(
     '(nil
      function abUnwrap
      name abUnwrap
      description "Unwrap with arbitrary modulus"
      category ("Custom Functions")
      analysis (nil
          general (nil
            args (wave modulus maxRelativeDelta )
              signals (nil
                    wave (nil
                          prompt "Waveform"
                          tooltip "Waveform"
              params(nil
                     modulus (nil
                           prompt "Modulus"
                           tooltip "Modulus"
                           guiRowHint 1
                           type float
                           default 180
                           required t
                     maxRelativeDelta (nil
                           prompt "Max Relative Delta"
                           tooltip "Maximum proportion of modulus which triggers unwrapping"
                           guiRowHint 1
                           type float
                           default 0.5
                           required nil
            inputrange t
      outputs(result)
  • debaabed
    Thanks for the immense help! I really appreciate the fast response.
    I tried this function and it does exactly what I needed.
    Thanks and Regards
    DB
