  3. Worst case delay measurement
  • Views 18393
Aalelai
Aalelai over 6 years ago
I have simulated an inverter in 180nm. I'm told to calculate the propagation delay and worst case delay of the circuit.
What is the method to calculate worst case delay either using calculator or graphical output ?
    ShawnLogan over 6 years ago
    Dear Aalelai,
    The cross() function in the Calculator may be used with a waveform to determine the time at which the waveform crosses a specific voltage threshold. One of its options allows you to select the slope of the waveform at which it crosses and a second option allows you to select which edge number of the waveform to use to determine the crossing time.
    Its options from the ocean reference manual follow. You may also use the cross function in combination with the clip() function to window the output of your delay cell to only consider the time after the input edge to the delay cell is applied to guarantee your propagation delay time is positive. I hope this helps.
    Shawn
    cross
    cross(
    o_waveform
    n_crossVal
    x_n
    s_crossType
    [ g_multiple [ s_Xname ] ]
    => o_waveform / g_value / nil
    Description
    Computes the X-axis value at which a particular crossing of the specified edge type of the
    threshold value occurs.
    Gets the time value (X axis) corresponding to specified voltage "/net9"=2.5V (Y axis) for
    the second rising edge.
    Arguments
    Value Returned
    Example
    cross( v( "/net9" ) 2.5 2 ’rising )
    o_waveform Waveform object representing simulation results that can be
    displayed as a series of points on a grid. (A waveform object
    identifier looks like this: srrWave:XXXXX.)
    n_crossVal Y-axis value at which the corresponding values of X are
    calculated.
    x_n Number that specifies which X value to return. If x_n equals 1,
    the first X value with a crossing is returned. If x_n equals 2, the
    second X value with a crossing is returned, and so on. If you
    specify a negative integer for x_n, the X values with crossings
    are counted from right to left (from maximum to minimum). If
    you specify x_n equals to 0, it returns all occurrences of the
    crossing events.
    s_crossType Type of the crossing.
    Valid values: ’rising, ’falling, ’either.
    g_multiple An optional boolean argument that takes the value nil by
    default. If set to t, the value specified for the x_n argument is
    ignored and the function returns all occurrences of the crossing
    event.
    s_xName An optional argument that is used only when g_multiple is
    set to t. It takes the value time by default. It controls the
    contents of the x vector of the waveform object returned by the
    function.
    Valid values: ’time, ’cycle
    o_waveform Returns a waveform if the input argument is a family of
    waveforms.
    g_value Returns the X-axis value of the crossing point if the input
    argument is a single waveform.
    nil Returns nil and an error message otherwise.
    Example
    cross( v( "/net9" ) 1.2 1 ’either )
    Gets the time value (X axis) corresponding to specified voltage "/net9"=1.2V (Y axis) for
    the first edge, which can be a rising or falling edge.
    cross(VT("/out") 2.5 0 0 t "time") (s)
    Returns multiple occurrences of crossing events specified against time-points at which each
    crossing event occurs.
    cross(VT("/out") 2.5 0 0 t "cycle") (s)
    Returns multiple occurrences of crossing events specified against cycle numbers, where a
    cycle number refers to the n’th occurrence of the crossing event in the input waveform.
  • Aalelai
    Aalelai over 6 years ago in reply to ShawnLogan
    Thank you shawn
    Andrew Beckett over 6 years ago in reply to Aalelai
    There's also the delay function in the calculator too...
