  3. Export Netlist with VerilogA subblock when there is no ADE...
  • Replies 8
  • Views 18847
Export Netlist with VerilogA subblock when there is no ADE license
quyleanh
quyleanh over 6 years ago
Dear all,
I would like to ask how to export netlist with VerilogA subblock when there is no ADE license.
I can export normal schematic view by using si -batch -command netlist command with a defined si.env file.
However, when exporting a schematic with VerilogA inside, the following error is outputed.
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 2.40s.
*Error* dbClose: argument #1 should be a database object (type template = "d") - nil
Here is my si.env file
simLibName = "xxx"
simCellName = "xxx"
simViewName = "schematic"
simSimulator = "auCdl"
simNotIncremental = 't
simReNetlistAll = nil
simViewList = '("auCdl" "schematic")
simStopList = '("auCdl")
hnlNetlistFileName = "netlist"
resistorModel = ""
shortRES = 2000.0
preserveRES = 't
checkRESVAL = 't
checkRESSIZE = 'nil
preserveCAP = 't
checkCAPVAL = 't
checkCAPAREA = 'nil
preserveDIO = 't
checkDIOAREA = 't
checkDIOPERI = 't
checkCAPPERI = 'nil
simPrintInhConnAttributes = 'nil
checkScale = "meter"
checkLDD = 'nil
pinMAP = 'nil
preserveBangInNetlist = 'nil
shrinkFACTOR = 0.0
globalPowerSig = ""
globalGndSig = ""
displayPININFO = 't
preserveALL = 't
setEQUIV = ""
incFILE = ""
auCdlDefNetlistProc = "ansCdlSubcktCall"
Could anyone help me this problem? Thank you.
    Andrew Beckett over 6 years ago +1
    The si.env you're describing is to produce a CDL netlist; Verilog-A doesn't make any sense for CDL (which is for physical verification, not simulation). If you want a spectre netlist, you need an ADE license…
    Andrew Beckett over 6 years ago in reply to quyleanh +1
    See this article: How to create spectre, hspice netlist using the batch mode OSS translator "si" and which licenses are required? Other OSS based netlisters auCdl, verilog, vhdl, systemVerilog Andre…
    The si.env you're describing is to produce a CDL netlist; Verilog-A doesn't make any sense for CDL (which is for physical verification, not simulation). If you want a spectre netlist, you need an ADE license.
  • quyleanh
    quyleanh over 6 years ago in reply to Andrew Beckett
    Thank you very much for you quick response.
    So if I want to export netlist for simulation (including VerilogA), which si.env configuration should I use?
    For example, the "simSimulator" should be "spectre"?
    And one last question, if I can't have ADE license, how can I export netlist in this case?
  • quyleanh
    Thank you very much for your help. I have tried the tutorial in your recommend article. There must be ADE license to export.
    PS: The link in My Account panel is incorrect with <%=profilelink%> postfix, please check. Thank you.
    I've no idea what you're asking me to check - I don't understand what's wrong?
  • quyleanh
    If I click to My Account, I will be redirected to this link
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/43854/%3C%=profilelink%%3E
    and the 400 Bad Request.
    You can try yourself.
    I'd already tried that (it worked for me) and I tried again, and it still worked. I'll ask IT about it.
  • quyleanh
    Thank you.
