  3. plotting waveVsWave across corner+global variable sweep...
  • Views 1774
plotting waveVsWave across corner+global variable sweep in ADEXL
dzakharian
dzakharian over 6 years ago
I'm running a simulation across corners, while stepping through a Global Variable in ADEXL. In this case the variable is TRIM_CODE, and I want to evaluate the trim gain, i.e., dVOUT/dTRIM_CODE.
If I run only one corner, I can do something like this:
waveVsWave(?x VAR("TRIM_CODE") ?y v("/VOUT" ?result "tran")
and then do "deriv" on that, which seems to work.
But when I decide I want to add couple corners, I can no longer do what I did above. With corners enabled, it appears that waveVsWave function "flattens" out the data and groups all point under one curve (for which 'deriv' returns nothing).  And I can't figure out how to do waveVsWave(?x VAR("TRIM_CODE") ?y v("/VOUT" ?result "tran") per corner, as a workaround.
Is there perhaps a better way getting what I'm after?
(I'm on version 6.1.8)
Many thanks in advance for your help,
David
