  3. Conversion of old Simulation Files
  • Views 15902
JavadBa
JavadBa over 6 years ago
I have some old libraries which contain schematics (in the .cdb format) and ADL states (which saved in the directory path instead of Cellview path).
I copied the specter folder of each library to its Cellview path, and then I used the conversion toolbox of Virtuoso to convert them. Still, only the schematic converted to .oa file and are visible in my new libraries.
How can I convert the ADL states as well? Regarding the ADL states have been saved in the directory path, should I copy them one by one to Cellview directory (however it didn't work), or is there another way to recall them?
Best,
    There's no need to convert state directories when moving to a newer version. Simply load the state in ADE L as you did before, or load them into the newer ADE Explorer tool. You can then save as a cellView (the only choice with Explorer).
    When you convert (using the conversion toolbox) ADE L cellViews from a CDB library to an OA library, nothing happens other than it copying the data across (since these cellViews are not in Open Access format). There's nothing in the conversion process to convert ADE state directories into cellViews - and you can't just copy them across manually because the file naming is different.
  • JavadBa
    JavadBa over 6 years ago in reply to Andrew Beckett
    Hello Andrew,
    As you said I load one of them from ADE L. But it can't load the state, the virtuoso shows the warning "No saved state exists for lib (ADC_Pipeline_Chip4_Testbenches): cell (Testbench_currentSinkSizing): simulator (spectre)."
    Despite that, I load it from the path which it exists:
    ekxserver2: --------/sim/artist_states/ADC_Pipeline_Chip4_Testbenches/Testbench_currentSinkSizing/spectre/state1> ls -al
    total 96
    drwx------                                           16 Apr 16 11:35 .
    drwx------                                           4 Apr 16 11:35 ..
    -rwx------                                           0 Apr 16 11:35 .sevSaveDir
    -rwx------                                          164 Apr 16 11:35 ADE_state.info
    -rwx------                                          1507 Apr 16 11:35 analyses
    -rwx------                                          10240 Apr 16 11:35 convergence
    -rwx------                                          247 Apr 16 11:35 cosimOptions
    -rwx------                                         1404 Apr 16 11:35 environmentOptions
    -rwx------                                         21 Apr 16 11:35 graphicalStimuli
    -rwx------                                         141 Apr 16 11:35 modelSetup
    -rwx------                                         1944 Apr 16 11:35 outputs
    -rwx------                                         4 Apr 16 11:35 rfstim
    -rwx------                                         135 Apr 16 11:35 simulationFiles
    -rwx------                                         1282 Apr 16 11:35 simulatorOptions
    -rwx------                                         27 Apr 16 11:35 spList
    -rwx------                                        180 Apr 16 11:35 variables
    Please let me know did I understand what you said correctly?
    /Javad
    Andrew Beckett over 6 years ago in reply to JavadBa
    Javad,
    I don't really understand what you're saying. You say you can't load it then you say that you can load it from the path where it exists. So isn't that OK? That's what you have to do - it's not going to automatically copy the state files into a different .artist_states directory - you'd need to point at the original .artist_states directory (unless you've copied the entire directory tree somewhere else).
  • JavadBa
    Sorry for my unclear explanation and thanks for your tips.
    I copied all those state files in the artist_states folder. And now from the ADE L, I can load it and even save it in the Cellview.
    Javad
