  3. Netlister's subcircuit naming convention
  • Replies 8
  • Subscribers 132
  • Views 4724
ZoltanT
ZoltanT over 5 years ago
Hi everybody,
I just stumbled upon a case where the netlister generated subcircuit names as `subckt libraryname_cellname_cellviewname port_list` instead of the usual `subckt cellname port_list` in the input.scs. How can this be enabled or disabled?
It made the simulation with dspf file problematic due to the different subcircuit naming. I overcome the issue by simply rebuilding the ADE's state. I am just curious what could have caused it.
Zoltan
The used Cadence version is ICADV 12.30.721.
Update: I've just found a saved ADE state, where I have found subcircuits with names with and without _schematic suffix. Also in this case there was no libraryname_ prefix.
    Zoltan,
    There's a number of cases where the view name gets appended. Sometimes it's because the same cell exists in more than one library; sometimes it's because instance or occurrence bindings have been used in the config which means that it has to be able to distinguish between different cells. Sometimes it's because the incremental netlister gets its state info messed up - and forcing a renetlist can fix it (there's a variable for this, but it's bad to set it in general because it can lead to performance loss). You might be able to clear out the netlist directory (if you're using ADE Explorer/Assembler, there's a tmp dir that needs clearing out too), but the best thing would be to contact customer support. Please mention CCR 1592892 where this is discussed in length, and a solution is being pursued to allow spectre to be told about the mapping from the DSPF subckt name to the netlister subckt name.
    • Vote Up +2 Vote Down
  • Ponien Lin
    Ponien Lin over 4 years ago in reply to Andrew Beckett
    Hi Andrew, I met the same issue. It adds "_schematic" to the cell name so the dspf include fail.  Could you point me where to find the discussion of "CCR 1592892"?
    Andrew Beckett over 4 years ago in reply to Ponien Lin
    There is no public discussion on this - I mentioned that CCR in the previous reply in order to suggest that Zoltan contacted customer support, and then referenced that (internal Cadence Change Request) number so that when the Application Engineer dealing with his case filed another issue with R&D, it could reference that existing internal discussion.
    So you should do the same thing...
  • Ponien Lin
    Understand. Thanks Andrew.
  • Frank Wiedmann
    Frank Wiedmann over 3 years ago in reply to Ponien Lin
    I just got a notice that this CCR has been implemented in ISR24 of IC 6.1.8 and ICADVM 20.1.
  • lchensd
    lchensd over 3 years ago in reply to Frank Wiedmann
    I recently ran into this exact issue running ic201_isr24. The netlister randomly appends the _schematic suffix to a subckt and it is making the use of dspf netlists unreliable.
    Andrew Beckett over 3 years ago in reply to lchensd
    The "randomness" is supposed to be fixed in ISR24 - see https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/51922/netlist-creation-issue/1383953#1383953 . There are still cases where the _schematic might be added (if instance-based or occurrence-based bindings are used). You might want to try setting:
    envSetVal("maestro.polo" "supportDspfMasterOption" 'boolean t)
    (in the .cdsinit). If that doesn't fix it, please contact customer support.
  • lchensd
    lchensd over 3 years ago in reply to Andrew Beckett
    Thank you, Andrew! I am using instance-based binding, so perhaps that is the root cause. I will try the above setting.
