  3. ADE L plotting error: vector::_M_range_check
  • Views 1816
ZoltanT
ZoltanT over 6 years ago
I face annoyingly often the problem that ADE does not plot any results, while CIW reports the error "The wsReloadCommand command generated an exception vector::_M_range_check.". The problem is circumvented by closing and reopening ADE after which the waveforms are plotted.
I have not found this error message in the knowledgebase or in the forum, so probably it is related somehow to my setup. I would like to avoid closing and reopening the ADE if there is any other way. I would be glad for any help or advice about the background of this error. I suspect that an invalid vector index is used, but I am clueless about what specific setting could invoke such an error in my side.
Current tool versions:  MMSIM: 19.10.063 & ICADV: 12.30.721.
    Andrew Beckett over 6 years ago +1
    This seems to be an issue with "Refresh" mode plotting in ADE, which has been superseded by plotting templates in IC618/ICADVM18.1. I would suggest you try moving to that instead (I don't think there's…
    This seems to be an issue with "Refresh" mode plotting in ADE, which has been superseded by plotting templates in IC618/ICADVM18.1. I would suggest you try moving to that instead (I don't think there's any fix to the specific issue you're seeing, which I only found one report of) - the plotting templates approach is definitely superior to the old refresh approach.
