  3. Can't Find Quantus QRC toolbar on the Layout Suite
  • Views 4055
Danielrayray
Danielrayray over 6 years ago
I want my layout verified by Quantus QRC. But, I can't find the tool bar on the option list ( as show in the picture)
I have tried to install EXT182 and configured it with iscape already, and also make some path settings on .bashrc, .cshrc. But, when I re-source .cshrc and run virtuoso again, I just can't find the toolbar.
If you have some methods, please let me know.
Thanks a lot!
Appreciated
My virtuoso version is: ICADV12.3
    Andrew Beckett over 6 years ago +1
    Not sure why this is - perhaps you should check through the steps in this article: Quantus/QRC Menu not appearing and how to verify the correctness of the Quantus environment configuration? If that doesn…
    If that doesn't solve it, please contact customer support.
  • Danielrayray
    Danielrayray over 6 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thanks for your rapidly reply and also for your materials. I will try it later!
    Best
  • Danielrayray
    Dear Andrew,
    The page is helpful! And the problem solved! Thanks a lot!
    Much appreciated
    Daniel
