  3. Delay Degradation vs Glitch Peak Criteria for Constraint...
  • Views 17388
Delay Degradation vs Glitch Peak Criteria for Constraint Measurement in Cadence Liberate
anurans
anurans over 6 years ago
This question is related to the constraint measurement criteria used by the Liberate inside view. I am trying to characterize a specific D flip-flop for low voltage operation (0.6V) using Cadence Liberate (V16).
When the "define_arcs" are not explicitly specified in the settings for the circuit (but the input/outputs are indeed correct in define_cell), the inside view seems to probe an internal node (i.e. master latch output)  for constraint measurements instead of the Q output of the flip flop. So to force the tool to probe Q output I added following coder in constraint arcs :
# constraint arcs from CK => D
define_arc \
-type hold \
-vector {RRx} \
-related_pin CP \
-pin D \
-probe Q \
DFFXXX
define_arc \
-type hold \
-vector {RFx} \
-related_pin CP \
-pin D \
-probe Q \
DFFXXX
define_arc \
-type setup \
-vector {RRx} \
-related_pin CP \
-pin D \
-probe Q \
DFFXXX
define_arc \
-type setup \
-vector {RFx} \
-related_pin CP \
-pin D \
-probe Q \
DFFXXX
with -probe Q liberate identifies Q as the output, but uses Glitch-Peak criteria instead of delay degradation method. So what could be the exact reason for this unintended behavior ? In my external (spectre) spice simulation, the Flip-Flop works well and it does not show any issues in the output delay degradation when the input sweeps.
Anuradha
  • Guangjun Cao
    Guangjun Cao over 6 years ago in reply to anurans +1
    Why do you not have access to the latest release? v16 is way too old. Which ever method the tool uses, the actual threshold decides the final constraint value. If you want to match constraint values…
  • Guangjun Cao
    If you let Liberate to decide on the criteria and what to probe, the algorithm is not open to public, even I do not have access. The final decision may be different even with different tool versions--- I don't understand why you refuse to move to the latest or newer release.
    10% degradation in delay just means a larger delay. your cell may still be working normally at the 10% increase. What will happen if all cells have 10% extra delay in a high speed chip with millions of cells? If this is still fine, then you can certainly increase the threshold.
    Guangjun
  • Guangjun Cao
    Guangjun Cao over 6 years ago in reply to Guangjun Cao
    Sorry that forgot to mention,
    what you have observed on changes to criteria, is NOT general. This depends on the circuits/behavior, as well as the tool/versions.
    Guangjun
  • Guangjun Cao
    and, change of criteria is NOT unintended behavior.
  • anurans
    anurans over 6 years ago in reply to Guangjun Cao
    Well I do not have access to the latest version right now. But the question is not related to the tool version.
    The delay degradation method is more pessimistic when it comes to constraint measurements than the glitch peak method (hence delay degradation is preferred for ultra low voltage libraries). As I mentioned in my question, I explicitly use the arc definitions (with -probe Q ), so that does not mean I let the "Liberate to Decide". By default the glitch_peak method is disabled and the delay_degradation method is enabled. So I expect the tool to strictly use delay_degradation instead of glitch_peak (as per the V16 and  latest V19.2 manuals).
    But as you said, if this depends on the tool version too, I will try to run the experiment in the latest version.
  • Guangjun Cao
    Which ever method the tool uses, the actual threshold decides the final constraint value. If you want to match constraint values with different approaches, you will have to change the probe/threshold, and maybe other constraint related parameters. if you want to use a particular probe (this can change the criteria and hence may change the threshold), or merit you may do so on arc-basis. please check the manual on define_arc.
    I would like to remind you this, most of the default settings are set based on big vendor's and most of our customer's requests. However, depending on your needs, eg. you believe the constraint with one method is too conserve, you may change the default, or provide explicit information/settings to the tool.
    guangjun
