  3. Is there a simple way of converting a schematic to an s...
  • Views 15353
Is there a simple way of converting a schematic to an s-parameter model?
MatthewLove
MatthewLove over 6 years ago
Before I ask this, I am aware that I can output an s-parameter file from an SP analysis.
I'm wondering if there is a simple way of creating an s-parameter model of a component.
As an example, if I have an S-parameter model that has 200 ports and 150 of those ports are to be connected to passive components and the remaining 50 ports are to be connected to active components, I can simplify the model by connecting the 150 passive components, running an SP analysis, and generating a 50 port S-parameter file.
The problem is that this is cumbersome. You've got to wire up 50 PORT components and then after generating the s50p file, create a new cellview with an nport component and connect the 50 ports with 50 new pins.
Wiring up all of those port components takes quite a lot of time to do, especially as the "choosing analyses" form adds arrays in reverse (e.g. if you click on an array of PORT components called X<0:2> it will add X<2>, X<1>, X<0> instead of in ascending order) so you have to add all of them to the analyses form manually.
Is any way of taking a schematic and running some magic "generate S-Parameter cellview from schematic cellview"  function that automates the whole process?
    No, there's nothing built-in to do this because it's not a terribly common thing to do. Normally people don't run sp analysis from a schematic design representing a passive network with that number of ports. Sounds like the kind of thing to do with some SKILL code to automate it.
    If you can live with individual ports (rather than vectored ports), then in that automation you could specify the port number on the instance, which means you don't have to specify it on the sp analysis. Another thought - I suspect if that if you specified the port name as X<2:0> then it would come out in the same order as the port (not sure that helps, but maybe it does?)
  • MatthewLove
    MatthewLove over 6 years ago in reply to Andrew Beckett
    Thanks for the reply, a SKILL-based solution is probably the way to go then.
