  3. VMT
  • Views 15926
VMT
sidm
sidm over 6 years ago
Hello All,
I am trying to launch virtuoso with the vsdp option in IC 6.1.7-64b.500.23
I am getting the below error. Can you please advise what is the issue here ?
$ virtuoso -sdp
[1] 76377
-sdp: Command not found.
I see the 95541 & 95543 license options available in the CIW -> OPTIONS -> LICENSES menu
Does this enable me to use the VSDP option and also to generate s-parameters for on-chip components ?
Any detailed replies will be great help.
    My guess is that virtuoso that you're running is not the virtuoso from the IC installation, but an alias or a wrapper script, and this is not passing the arguments through to the executable.
    Check what "which virtuoso" responds with, or what "alias virtuoso" responds with.
    From a little experiment, I can reproduce your problem by doing:
    alias virtuoso='virtuoso &'
    and then using:
    virtuoso -sdp
    gives this issue (the clue is the [1] nnnnn output which suggests that something has been backgrounded).
    If that's what you've done, and it's a bash alias, then you could use this instead:
    alias virtuoso='virtfunc(){ virtuoso "$@" & }; virtfunc'
    This creates a temporary function, and allows the arguments to be passed before it backgrounds the process.
  • sidm
    sidm over 6 years ago in reply to Andrew Beckett
    Thanks for the reply Andrew, yes there is an alias in the source script.
    Please see the results below
    which virtuoso
    virtuoso: aliased to virtuoso &
    Also I see the 95541 & 95543 license options available in the CIW -> OPTIONS -> LICENSES menu
    Does this enable me to use the VSDP option and also to generate s-parameters for on-chip components ??
    Andrew Beckett over 6 years ago in reply to sidm
    Sounds as if you might be using csh not bash, in which case using:
    alias virtuoso 'virtuoso \!* &'
    would solve the problem. As for usage of VSDP, I wouldn't say I have much experience of using VSDP, so I'd advise you to look at Virtuoso System Design Platform Multi-Technology Simulation Demonstration (there are other rapid adoption kits available - go to http://support.cadence.com then pick Resources->Rapid Adoption Kits and in the Search in Rapid Adoption Kits box (not the search at the very top of the page), type "VSDP" and you'll find a few relevant kits.
  • sidm
    The server where I am accessing virtuoso doesn't have internet access so clicking on any of the RAKs etc.. don't work
    Hence can you please suggest alternate method to access the videos/documents ?
    No, you'll have to access it from somewhere that does have internet access... (like you do to respond here). You can also use the Cadence Online Support app from the app store/play store.
