  3. rfTlineLib sbend
  • Views 14491
rfTlineLib sbend
dzakharian
dzakharian over 6 years ago
I'm modeling a PCB trace using rfTlineLib components, and wanted to clarify a couple things about "sbend" discontinuity in particular.
1. Documentation for this component in Cadence does not provide any indication re: how the angle is defined.  I found an older ADS sbend model here (https://edadocs.software.keysight.com/pages/viewpage.action?pageId=5906296), which states direction of angle for positive/negative numbers.  Can I assume it's same for the sbend in rfTlineLib?
2. Documentation also indicates that I should be able to specify negative angles, but every time I enter a negative number for the angle in the properties, it defaults immediately to 90deg... is this behavior expected?
Many thanks in advance,
David
    David,
    This looks like an oversight in the rfTlineLib implementation. The underlying component in spectre seems to be limited to within -90 and 90, but both sbend and mbend have checks to limit the angle between 0 and 90.
    You should contact customer support to request that this is fixed.
