  3. probe tcl command with time_window option
  • Views 19198
apogee
apogee over 6 years ago
I'm running AMS simulation and using probe.tcl file to save the waveform. The size of output file is really big so I need to have an option of only save the waveform during a window of simulation time (i.e. only save waveform from 1us to 2us sim time).
In Spectre Guide, I found an option for save statement: time_window=[t1 t2] . But I could not find anything similar for tcl probe command option ...
Thanks.
    You could do this (from a quick experiment by doing):
    run 20us
    probe -create -name dacOut -emptyok -database ams_database {top.dacOut}
    run 15us
    probe -delete dacOut
    run
    I thought this might work, but unfortunately it doesn't:
    probe -disable dacOut
    run 20us
    probe -enable dacOut
    run 10us
    run 5us
    run 10us
    run
    Anything fancier, you'll probably need to contact customer support.
  • apogee
    Thanks Andrew. Your suggestion works.
