  3. Is there a setting to let multiple runs of transient noise...
  • Views 18620
Is there a setting to let multiple runs of transient noise run in parallel
ExcaIibur
ExcaIibur over 6 years ago
The version IC6.1.8-64b.500.4
I am running transient noise and I specified 10 runs. From the output log file, I see that the 1st run takes a seed of 1 and the 2nd run takes a seed of 2. What surprises me is that these 10 runs dont in parallel. I dont think that is required.
Is there a setting or workaround to let them run in parallel?
    Andrew Beckett over 6 years ago +1
    That's because this then uses a spectre native sweep analysis, and that doesn't have access to the job distribution capabilities within ADE. Rather than turning on Multiple Runs, set the Noise seed to…
  • ExcaIibur
    ExcaIibur over 6 years ago in reply to Andrew Beckett +1
    Got it. I am using Assembler and it works like a charm.
    Rather than turning on Multiple Runs, set the Noise seed to (say) VAR("ITERATION") and this will add a new variable in ADE. If this is ADE Explorer (or Assembler) you can set the ITERATION to 1:1:10 to sweep from 1 to 10, and based on your Setup->Job Setup you can control how many run in parallel.
    If using ADE L, then you'd have to go into distributed mode, and then do a Tools->Parametric Analysis to do the same kind of sweep. It's much easier in Explorer/Assembler though.
  • ExcaIibur
