  3. Attached technology library is not showing up in an instantiated...
  • Subscribers 133
  • Views 15307
Attached technology library is not showing up in an instantiated model
wgtkan
wgtkan over 6 years ago
First, I would like to thank you so much for your help with the following question.
I am trying to characterize an NCSU-CDK-1.6.0.beta. When I created a new library with one of their technology (ami06) attached and created a new view of an inverter and instantiated an nmos the transistor from the ami06 is not showing up.
It seems that the CDS_SITE is defined for another technology twice. I have a 45nm GPDK that shares the same $CDK_DIR and how should I separate the two? Meaning how should I assign $CDK_DIR for each of the two different technologies?
I am using cadence virtuoso version  IC6.1.8-64b-500.9 and spectre version: spectre191
Thank you so much.
    It's probably best to ask NCSU - I am not familiar with their PDKs (which are for academic use, I presume).
  • wgtkan
    wgtkan over 6 years ago in reply to Andrew Beckett
    Hello Andrew,
    Thank you for your response.
