  3. Using pre-defined constants in ADE-L (Analog expressions...
  • Views 17046
Using pre-defined constants in ADE-L (Analog expressions)
mmVivek
mmVivek over 6 years ago
The Analog Expression Language Reference manual states that certain constants are pre-defined for use, e.g. boltzmann, charge, pi, sqrt2.
However, attempting to create components that make use of these seems to result in the simulator asking one to define the value of these parameters.
I am curious as to why these constants are not being recognized automatically.
Vivek
    Andrew Beckett over 6 years ago +1
    Vivek, This is something that broken in the change from "socket" netlisters such as cdsSpice, spectreS, hspiceS to "direct" netlisters such as spectre, hspiceD and so on. These AEL constants were no…
    Vivek,
    This is something that broken in the change from "socket" netlisters such as cdsSpice, spectreS, hspiceS to "direct" netlisters such as spectre, hspiceD and so on. These AEL constants were no longer dealt with during net listing, and were just passed through to the simulator. In spectre, the constants are named differently (see "spectre -h constants") to be M_K, M_SQRT2 etc. I found some discussion of this in an old CCR 231925 in which the documentation was supposed to have been updated to reflect that the fact that this was happening, but that seems to have vanished from the documentation too.
    My view is that the spectre netlister should map boltzmann to M_K, pi to M_PI, sqrt2 to M_SQRT2 etc. I would suggest you contact customer support and ask for this to happen (please reference this thread, and ask the application engineer to put me on copy for an Cadence Change Request (CCR) they file).
    In the meantime you might be able to work around it for spectre using M_K, M_SQRT2 in the expression, but this may have issues then when using different simulators - e.g. AMS. Note, I didn't check the behaviour - it's possible that ADE may mistakenly see these as global variables.
  • mmVivek
    mmVivek over 6 years ago in reply to Andrew Beckett
    Thanks for the detailed response Andrew!
    I have submitted a CCR and requested that you be placed on copy.
    Vivek
