  3. Force simulation to overwrite previous .fc files
  • Views 14621
david73
david73 over 6 years ago
Hi
I have a testbench in which i want to recycle the .fc file of one simulation to be a node set for the next simulation.
I have a set up cross corner so that the file is always written to a deterministic location, and the nodeset is read from the same location
The problem is, that if there is a file of the same name, the simulation won't wrte a new updated .fc file there.
I see that the file is "touched" but when i open it, I see that it is old
How can i tell Spectre/ADE to overwrite the old file if it finds one of the same name?
    David,
    That's not true. Spectre will quite happily overwrite a file with the same name as a writefinal file from the analyses. Perhaps you're seeing an NFS/filesystem issue where you're seeing a stale cache - which is a problem with the OS/filer setup, and not the simulator. I have never seen any issue with spectre not writing to an existing file in this way, and I'd be absolutely amazed if that was ever the case in any version (I just checked myself to make double sure, and it definitely doesn't behave this way in a few experiments).
