  3. BPSK modulation/demodulation and EVM
  • Views 2821
dzakharian
dzakharian over 6 years ago
I've been trying to figure out if there is a way to demodulate a BPSK modulated carrier and get plots like EVM from transient simulations.  Best info/pointer I could find was to use a predefined LTE standard using rfLib 'lte' source, but that isn't my use case (and the source doesn't support BPSK anyway).
Any guidance would be much appreciated.
I'm on 6.1.8.
    You could use the wireless analysis (a choice from envlp analysis) and then use the msource which is a generic (not tied to a standard) wireless source. You then use wprobe at your probe points.
    I'd say it's probably best to contact customer support about this though to make sure it does what you want.
  • dzakharian
    dzakharian over 6 years ago in reply to Andrew Beckett
    Thanks Andrew, I'll try that, and will also contact customer support as suggested.
