  3. Reporting simulation time for suspended simulations
  • Replies 10
  • Views 20149
debaabed
debaabed over 6 years ago
Hi All,
I am running Spectre .tran simulations from command line. Sometimes I need to kill the simulations from the Linux terminal. I have noticed that the Spectre log file doesn't update the time when the job gets killed. Is there a way to print out the simulation time at the end of log file showing the start time, end time and the elapsed time for the simulation, even for simulations which are killed in between.
DB
    DB,
    Which version are you using? I just used ctrl-C to kill the job, and got:
    Spectre received SIGINT.
    Saving the states into file at t=266.853 us...
    Killed by user.
    Aggregate audit (3:57:55 PM, Tue Jun 16, 2020):
    Time used: CPU = 2.83 s, elapsed = 2.89 s, util. = 98.1%.
    Time spent in licensing: elapsed = 51.9 ms.
    Peak memory used = 53.3 Mbytes.
    Simulation started at: 3:57:52 PM, Tue Jun 16, 2020, ended at: 3:57:55 PM, Tue Jun
    16, 2020, with elapsed time (wall clock): 2.89 s.
    spectre completes with 0 errors, 0 warnings, and 5 notices.
    How are you killing the job?
  • debaabed
    debaabed over 6 years ago in reply to Andrew Beckett
    Hi Andrew
    I am using ctrl-C to kill the job. I am using SPECTRE191.
    Is there something needs to specified for spectre options?
    DB
    Andrew Beckett over 6 years ago in reply to debaabed
    I tried with both SPECTRE 18.1 and 19.1 (latest hot fixes of each, but I'd be surprised if that made a difference). It was a transient analysis too. No special options (just spectre file.scs or spectre +aps file.scs). What are you running?
    ShawnLogan over 6 years ago in reply to Andrew Beckett
    Dear Andrew and debaabed,
    Using spectre Version 18.1.0.556.isr13, and issuing an LSF kill command on one of a set of Assembler simulations that was in progress, I also verified that the resulting simulation spectre.out file contains the elapsed time of the interrupted simulation:
    ...Spectre received SIGINT sent from PID: 133413 with UID: 0.
    Process hierarchy of PID 133413 :
        PID        COMMAND
        133413     /tools/lsf/Current/10.1/linux2.6-glibc2.3-x86_64/etc/sbatchd
        118432     /tools/lsf/Current/10.1/linux2.6-glibc2.3-x86_64/etc/sbatchd
    Saving the states into file at t=1.19042 us...
    Killed by user.
    Aggregate audit (4:16:30 PM, Tue Jun 16, 2020):
    Time used: CPU = 32.1 s, elapsed = 32.2 s, util. = 99.5%.
    Time spent in licensing: elapsed = 92.5 ms.
    Peak memory used = 125 Mbytes.
    Simulation started at: 4:15:58 PM, Tue Jun 16, 2020, ended at: 4:16:30 PM, Tue Jun 16, 2020, with elapsed time (wall clock): 32.2 s.
    spectre completes with 0 errors, 2 warnings, and 3 notices.
    I was curious as I have a shell script that compiles all the simulation times for an Assembler/ADE-XL simulation run to create a histogram and wanted to verify it handled a simulation ending prematurely correctly.
    Shawn
  • debaabed
    debaabed over 6 years ago in reply to ShawnLogan
    Hi Andrew and Shawn
    I am running a transient simulation.
    The command line is as below
    /cad/tools/cadence/SPECTRE191/tools.lnx86/bin/spectre -64 -E +lqt 0 \
    +lsuspend +mt=4 +preset=cx  \
    input.spe =log \
    ./LOGS/input.spelog
    DB
    ShawnLogan over 6 years ago in reply to debaabed
    Dear debated,
    I updated my environment to a version of 19.1 to allow me to run spectrex and used a spectre input file " input.scs". The run line, which I called "testx" is shown below and mimics what I believe is your run line:
    $ cat testx
    input.scs =log \
    ../psf/input.spelog
    I issued a Control-C to interrupt the interactive simulation and printed the last 20 lines of the output log and also include the version I am using:
    $ testx
    ^C
    Memory fault(coredump)
    $ tail -20 ../psf/input.spelog
    iprobe = 18.18 % of total equations
    During simulation, the CPU load for active processors is :
    0 (91.4 %) 1 (5.8 %)
    Total: 97.3%
    Saving the states into file at t=5.34581 us...
    Killed by user.
    Aggregate audit (12:19:13 AM, Wed Jun 17, 2020):
    Time used: CPU = 127 s (2m 6.8s), elapsed = 135 s (2m 14.6s), util. = 94.2%.
    Time spent in licensing: elapsed = 7.5 s, percentage of total = 5.57%.
    Peak memory used = 115 Mbytes.
    Simulation started at: 12:16:58 AM, Wed Jun 17, 2020, ended at: 12:19:13 AM, Wed Jun 17, 2020, with elapsed time (wall clock): 135 s (2m 14.6s).
    spectre completes with 0 errors, 4 warnings, and 9 notices.
    $ grep -e "Vers" ../psf/input.spelog
    Version 19.1.0.348.isr6 64bit -- 1 May 2020
    Hence, I am still seeing the elapsed time measurement in the output log. It might be insightful if you would attach your output log of the interrupted simulation. I am wondering if simulating your netlist is producing some other type of simulation error and hence the process termination sequence is different than the processes Andrew and I are observing - if that makes any sense!
    Shawn
    ShawnLogan over 6 years ago in reply to ShawnLogan
    Dear debaabed,
    My apologies for the error in my prior post - my spell checker decided your userid should be "debated" in lieu of your correct userid of debaabed. Sorry!
    Shawn
  • debaabed
    Hi Shawn and Andrew,
    With ctrl-<C> I am able to get the simulation time log at the end of the file.
    But with ctrl-<Z> to suspend the simulation and then finally killing it, doesn't print the simulation time. I miscommunicated this earlier on this therad.
    Why doesn't second method work?
    Debasish
    Hi Debasish,
    When you've suspended the simulation (using signal TSTP, i.e. ctrl-Z), then it goes into a particular handler to suspend the license usage. If you then kill it after that, it's still in this suspend mode - otherwise it would have to reclaim the license and then exit through the normal path.
    This strikes me as a fairly unusual requirement - to suspend the simulation, then kill it, and expect it to report on what it's done so far. If you really want it, you can resume the simulation then kill it.
    Most customers would not want the "kill" to have to reclaim the license to run through the normal flow to write the state file and so on - because a) that would temporarily consume the license, and potentially they may have to wait for it to be available.
  • debaabed
    Thanks for the explanation.
    The scenario is such that multiple long simulations are going on, and to temporary release the licences, few long sims are suspended. And in some cases, killed afterwards. But looks like the correct as you described is way to first bring the job to foreground, and then use ctrl-<C> to log the simulation time.
    DB
