  3. Is there any way to get the name of all components I use...
  • Views 16545
Is there any way to get the name of all components I use in schematic editor?
BaaB
BaaB over 6 years ago
Is there any way to get the name (or a list) of all components/devices from a library I use in schematic L (version IC6.18 -64b.500.8)?
for example (nmos5v, nmos2v, rnhpoly, etc).
I checked netlist file. It's kind of OK but it has more info than what I need so I would have to copy and paste each device into a file.
    Andrew Beckett over 6 years ago +1
    Edit->Hierarchy->Print Tree. If you only want this level of hierarchy (and nothing beneath this), you can use Top to current as the choice for Display on the form that appears. Andrew.
  • BaaB
    BaaB over 6 years ago in reply to Andrew Beckett
    Perfect! Thanks for the tip.
