  3. Cmin as as dynamic parameter change
  • Views 15188
abhishekMXL
abhishekMXL over 6 years ago
Hi Team,
              I would like to know if I could dynamically ( in transient simulation) change cmin using dynamic parameter. When I looked into the parameter list in the drop down menu, I didn't find cmin.
Any help is appreciated.
Abhishek
    This is not possible currently (it's not just a UI limitation, spectre doesn't support this natively). I suggest you contact customer support with a reason as to why you want this so that an enhancement request can be filed on your behalf.
