  3. How can perform AC analysis for switch capacitor circuit...
  • Subscribers 128
  • Views 16842
How can perform AC analysis for switch capacitor circuit filter
VictorArzate
VictorArzate over 5 years ago
Im working on a Low pass filter switched capacitor filter and Im using Cadence Virtuoso. I wolud like to know if it its possible to perform an AC Analysis
    You would need to use pss and pac. You cannot use standard ac on a switch cap circuit because it doesn't have a time invariant steady state (operating point). You would normally simulate a period of the clock using pss, and then do a small signal analysis using pac around that time-varying operating point.
    This is discussed in this paper: https://designers-guide.org/analysis/sc-filters.pdf
