  3. Difference between mustJoinNet() and joinableNet() commands...
  • Views 14030
Difference between mustJoinNet() and joinableNet() commands in Assura
NagarajPadman
NagarajPadman over 6 years ago
I have two vss! pins at the top level of the chip which are supposed to be separate on the top level of the chip. But they both short to the P substrate of the chip. Eventually they will be shorted on the PCB. I tried changing the names of one of the pins from vss! to VSS_QUIET. I still get an LVS mismatch probably because they both are shorted through the P substrate. I changed the pin name back to vss!. That doesn't provide an LVS match either. If I use the                      joinableNets( cell(root) "vss!") command I get an LVS match. But if I use the mustJoinNet( cell(root) "vss!") I do not get an LVS match. What's the difference between the two commands? Which one is applicable in this situation?
