  3. How can I hide cell name of components in schematic?
  • Views 19282
BaaB
BaaB over 6 years ago
I know I can do that by changing its value in Edit Object Properties however it would take ages to do that manually for all components.
If I change in Apply To to all components then I worry that would apply the same size for all transistors and that would be really bad.
    Andrew Beckett over 6 years ago +1
    The VIew->Hide Instance Labels don't provide that level of granularity, and some SKILL I wrote elsewhere on these forums (abToggleLabelsForPlotting) also don't. You could do: techGetLP(techGetTechFile…
    Andrew Beckett over 6 years ago in reply to BaaB +1
    Redraw the schematic - typically the "F6" schematic redraws, but it's also in View->Redraw. To turn it back on again, use: techGetLP(techGetTechFile(ddGetObj("tsmc18")) list("device" "annotate"))~>visible…
    You could do:
    techGetLP(techGetTechFile(geGetEditCellView()) list("device" "annotate"))~>visible=nil
    which will turn the visibility of all such labels off (you have to redraw after making the change). They will remain invisible for the rest of the session. You could do this in your .cdsinit by doing:
    techGetLP(techGetTechFile(ddGetObj("tsmc18")) list("device" "annotate"))~>visible=nil
  • BaaB
    BaaB over 6 years ago in reply to Andrew Beckett
    Thanks. What do you mean by redraw, redrawing all schematic?
    Does that apply to all schematic? Is there a reset command to remove it or I should close Cadence tool and open it again?
    Actually I just want to hide it just to take picture of it and then leave it visible again.
    techGetLP(techGetTechFile(ddGetObj("tsmc18")) list("device" "annotate"))~>visible=t
    No need to quit.
  • BaaB
    Yeah, it all works well now.
