  3. staircase function
  • Views 20256
staircase function
vvdb
vvdb over 6 years ago
To measure the offset of a comparator, I need a staircase funnction as shown in the figure. How can I generate this function in Cadence. I thought maybe with Verilog A, but I am not used to work with Verilog. For example, I would like to have a staircase function from 1.1V to 1.4V with step size 100 uV.
    Since this wasn't a SKILL question, I moved it into the Custom IC Design forum.
    Verilog-A is the simplest way. Potentially you could have used an existing Verilog-A model for a DAC, and then maybe an ideal ADC to drive that, but then  you need the right resolution. It's easy enough with Verilog-A.
    Here's the code:
    // VerilogA for rampgenerator
    `include "constants.vams"
    `include "disciplines.vams"
    //	vramp,  (output) input voltage for comparator, non-inverting
    //      clk,  clock signal for the comparator
    module rampgenerator(vramp, clk);
    input		clk ;
    output		vramp ;
    electrical 	vramp, clk ;
    parameter	vth=1 ;			// clk threshold voltage
    parameter	resolution=100u ;	// resolution of the ramp
    parameter   maxin = 0.8 ;		// maximum input level
    parameter   minin = 0.5 ;
    parameter   td = 100p ;	// delay time
    parameter	tr = 100p ;	// rise time
    parameter   initdirection = 1;
    real    offset ;
    integer direction ;
    analog
    begin
       @(initial_step("static","tran")) begin  // On initialization,
        if (initdirection > 0) begin
    	    offset = minin;
            direction = 1 ;
        end
        else begin
    	    offset = maxin;
            direction = -1 ;
        end
       end
       @( cross( V(clk)>vth, -1 )) begin
    	offset = offset + (direction * resolution) ;
       end
       if(offset > maxin-resolution/2) begin
          direction = -1 ;
       end
       else if(offset < minin+resolution/2) begin
          direction = 1;
       end
       V(vramp) <+ transition( offset, td, tr, tr ) ;
    end
    endmodule
    You'd need to set minin to 1.1, and maxin to 1.4 on the instance of the symbol (use the "Use tools filter" to see the available parameters on the edit properties for the instance of the ramp generator), set the rise times of the steps appropriately (don't make them too sharp if your ramp is rising slowly) and then use a pulse source to clock the input - that allows you to control the rate of the ramp. Here's a zoomed in picture of the graph it produces:
