  3. Can Liberate take encrypted spice netlist
  • Views 15834
KC Lee
KC Lee over 6 years ago
Hi All,
  Does anyone know if Liberate can take encrypted spice netlist?  Or if this standard cell characterization tool can take encrypted spectre netlist?
Thanks.
KC
  • Guangjun Cao
    Guangjun Cao over 6 years ago
    Liberate uses Spectre netlist parser. So, in theory, if Spectre can read the encrypted netlist, then it can be used with Liberate. However, I am not 100% sure. There might be problems when Liberate creates simulation decks. You might have to force the tool not to flatten the netlist (extsim_flatten_netlist=0).  Do you have an issue with it?
    Guangjun
  • Guangjun Cao
    Guangjun Cao over 6 years ago in reply to Guangjun Cao
    make sue you use '-extsim spectre' option for char_library command.
    Liberate reference manual does mention encrypted netlist in in one place.-- check description for extsim_exclusive
    Guangjun
