  3. matching constraint in extracted view simulation
  • Views 14737
PBWU
PBWU over 6 years ago
In IC6, device matching constraints are stored as constraint views of a cell. While it works OK with schematic pre-layout monte-carlo simulation, where the constraint views are effective clearly. However, when replacing the cells with PEX extracted views, the same monte-carlo simulation gives different results of matching performance. I think it is because that the constraint views are not connected to the extracted view netlist (instance name change). I wonder if there is a formal method to preserve the constrained instance paths to be exactly the same before and after layout? I realized in IC5, the same issue should exist.  FYI, I am using Calibre PEX.  Thanks.
    I don't think there's any support for this, although you're clearly not comparing like with like. Typically m-factored devices pre-layout are fully correlated, whereas they aren't post-layout (because each finger is extracted separately, for example).
    In general setting up correlation constraints is not that widely used, because the "mismatch" models from most foundries are actually modelling the remaining local random variation, and are not trying to model systematic effects caused by poor alignment/orientation in the layout - so it's questionable as to the value of setting up correlation coefficients anyway (what should you set the coefficients to, especially when this is not what has been characterised by the foundry).
    Even if we had implemented some smarts to map devices across to the post layout names (which I don't think we have), it's unlikely that would work with a non-Cadence extractor as there's far less information about the mappings that were performed.
    Either way, you probably should contact customer support about this.
