  3. Defining viva background color changed from IC6.1.7 to 6...
  • Views 21864
Defining viva background color changed from IC6.1.7 to 6.1.8?
CADcasualty
CADcasualty over 6 years ago
Back when I was using IC6.1.7 I had the following in my .cdsinit to get everything on a white background as my default:
envSetVal("viva.rectGraph" "background" 'string "white")
envSetVal("viva.rectGraph" "foreground" 'string "black")
Now that I'm in IC6.1.8 that doesn't appear to work anymore, although the documentation still appears to indicate it would. Every time I run a sim and do a plot I get the usual black background. I can go into the preferences (Edit->MultiGraphProperties) and change it to be white. That preference setting does work (sort of) in that the background color for the current plot changes to white when I click on OK, but the very next time I make a plot it's on a black background again and when I look into the preferences it's still set to be white. Did something change in 6.1.8  and should I be using different commands in my .cdsinit?
    Andrew Beckett over 6 years ago +1
    envSetVal("viva.graphFrame" "background" 'string "white") How can I change the background color in the ViVA waveform window ?
  • CADcasualty
    CADcasualty over 6 years ago in reply to Andrew Beckett
    envSetVal("CADcasualty.emotion" "happiness" 'string "great")
