  3. Importing Verilog-A code
  • Views 15495
Hosseineslahi7
Hosseineslahi7 over 6 years ago
Hi All,
I wish you are well.
I have imported a Verilog-A code of a specific model of a transistor in Cadence. I could create transistor symbol and run simulations for a few days. However, after a while, I saw this error once I tried to run the same simulations:
"Internal error found in spectre during AHDL read-in, during circuit read-in, during hierarchy flattening.
Encountered a critical error during simulation. Please run `mmsimpack' to pack the test case (use mmsimpack -h option to get detailed usage), and submit the case via Cadence Online Support, including the package tar file and any other information that can help identify the problem.
    FATAL (SPECTRE-18): Segmentation fault."
This is weird because it was working and, then, stopped suddenly. I wonder if anyone sees something like this before? And, is there any solution?
Cheers,
    You should do what the error message says - report it to Cadence support. It's almost certainly a bug, and diagnosing it without seeing the model and a testcase that demonstrates the problem is going to be hard. Something must have changed to trigger the error (simulators are general deterministic beasts), but it's almost certainly data dependent.
    If you're not using a very recent Spectre version, you might want to try with something that is as up to date as possible (e.g. the latest SPECTRE19.1 hot fix) as it's quite possible that whatever issue it's hitting has been solved already.
