  3. unwanted symbol instance in the layout
  • Views 13495
William Woo
William Woo over 6 years ago
Hello.
I am user of IC6.1.7 with GPDK180_v3.3.
From time to time when I started to run DRC, unexpected schematic symbols are added, which results in VDB error.
Of course, when such a case occurs, I manually delete unexpected schematic symbol that I didn't add in the lay out to run drc in a normal way. But it feels cumbersome.
I don't why such symbols, usually nmos or pmos(one or two), are added in the layout although I did nothing.
Do you have any answer?
    This seems pretty unlikely to me and I've not heard of this happening before (I struggle to imagine how running DRC - you didn't say which tool, but I'm assuming Assura) can create instances in the layout. Far more likely is that you pressed a bind key or did something to create the instance in the layout without realising.
