  3. ModGen routing problem in Cadence Virtuoso
  • Views 16503
Senan
Senan over 6 years ago
Hello
I started to work with ModGen (Module Generator), I started the new experiment with simple differential pair transistors as you see from the picture. I followed the Cadence help to create the Modern,
My problem is when I run the routing (after setting the Trunks and Topologies), Cadence will miss the contact of the transistors gates and the sources of the upper array row.
Could you please help me to fix this issue
I am using Cadence Virtuoso IC6.1.8
Many thanks
    Please contact customer support. Trying to diagnose this without seeing the data or having a screen-sharing session is going to be hard - it would be much easier to see the setup and then spot if anything is wrong (or if it is a bug).
  • Senan
    Senan over 6 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thank you for your reply
    if you allow me I will try to post the setting before going to contact the customer service, as you see the software i able to recognize the connection but missing to route it
