  3. Getting/highlighting all input pins of a design in sche...
  • Views 4810
Getting/highlighting all input pins of a design in schematic
SunnyB
SunnyB over 6 years ago
I am working on a huge schematic in virtuoso with lot of pins. I wanted to know if there is any way that I could highlight or get a list of all the input pins only in the design.
Sunny
    Andrew Beckett over 6 years ago +1
    Sunny, You could use this code: procedure(CCFselectPinsByDir(@key (cellView geGetEditCellView()) (direction "input")) foreach(term cellView~>terminals when(term~>direction==direction foreach(pin…
    Andrew Beckett over 6 years ago in reply to SunnyB +1
    You can't select instance pins using geSelectFig since they are not level-0 objects (i.e. shapes or instances within the schematic directly). They live within the master that of the symbol that is instantiated…
    Sunny,
          foreach(pin term~>pins
            foreach(fig pin~>figs
              geSelectFig(fig)
      t
    If you just call CCFselectPinsByDir() it will select all input pins; if you use CCFselectPinsByDir(?direction "output") it will select all output pins. You can then see the names in the navigator (note, this will add to the selection, so you may want to deselect everything first), or you can list their names by doing:
    geGetSelSet()~>pin~>term~>name
  • SunnyB
    SunnyB over 6 years ago in reply to Andrew Beckett
    Thanks Andrew! This was very helpful. Any way this selection of input terminals could also show up on the symbol for the schematic? I tried this code on the schematic and it works, but if I come one level up from the schematic and see it as a symbol, there is no selection made there. I assume this is happening because the symbol does not have actual pins and this code is meant for cellviews with actual pins. I tried playing around with the code and modifying it to see if I can get it working for the symbol too, but couldn't do so.
    Tried something like the code below but it seems that instance terminals do not have figs as their attributes.
      foreach(inst cellView~>instances
        foreach(term inst~>instTerms
            foreach(fig term~>figs
                geSelectFig(fig)
      t
    You can't select instance pins using geSelectFig since they are not level-0 objects (i.e. shapes or instances within the schematic directly). They live within the master that of the symbol that is instantiated. So your code wouldn't work for two reasons - one there are no figs on the term object, and secondly, geSelectFig wouldn't have been able to select them anyway.
    This code would work however:
    procedure(CCFselectInstPinsByDir(@key (cellView geGetEditCellView())
        foreach(instTerm inst~>instTerms
          when(instTerm~>direction==direction
            foreach(pin instTerm~>term~>pins
                geSelectObject(fig list(list(inst 1 0 0)))
      t
    Note that to see the results of the selection, geGetSelSet() won't help - you'd need to use geGetObjectSelectedSet() instead. This also depends on you having "pin" checked in the instance objects part of Edit->Select->Filter - otherwise you're not allowed to select the lower level shape.
    You can also use hsmGetSelectedSet() to get a different representation fo the hierarchical selections.
